[postgis-devel] Issue 141 in postgis: AsGML multipoint issue on MacOS X
codesite-noreply at google.com
Fri Mar 20 05:45:32 PDT 2009
Updates:
Status: Testing
Comment #2 on issue 141 by olivier.courtin: AsGML multipoint issue on MacOS
X
http://code.google.com/p/postgis/issues/detail?id=141
Hi Mark,
I don't really think there's a direct link, as for #141, it's clearly a
conceptual
error in length size computation.
Fixed as r3910
The only common point (for the moment) is that both #141 and #119 appears
only on
some platforms
I will rebuild my PostgreSQL with assert, to see if it could help
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
