[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com
Sat Mar 21 08:22:10 PDT 2009
Comment #18 on issue 119 by olivier.courtin: ST_AsSVG crashed DB backend
http://code.google.com/p/postgis/issues/detail?id=119
Mark, Regina
Thanks for all theses informations !
I do check again buffer size calculation for polygons
Olivier
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
