[postgis-devel] Issue 119 in postgis: ST_AsSVG crashed DB backend with large geometries.
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 21 11:19:05 PDT 2009
Comment #19 on issue 119 by olivier.courtin: ST_AsSVG crashed DB backend
http://code.google.com/p/postgis/issues/detail?id=119
Mark, Regina
Could you test again with r3921 ?
i think this one will be good !
Olivier
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
