[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
codesite-noreply at google.com
Sun Mar 22 06:06:45 PDT 2009
Comment #7 on issue 142 by mloskot: 1.4 snapshot build is broken
http://code.google.com/p/postgis/issues/detail?id=142
Trying to connect to SVN, I'm getting this error:
mloskot at dog:~/dev/postgis/_svn$ svn co
http://svn.refractions.net/postgis/trunk trunk
svn: OPTIONS of 'http://svn.refractions.net/postgis/trunk': Could not read
status
line: Connection reset by peer (http://svn.refractions.net)
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
