[postgis-devel] Issue 142 in postgis: 1.4 snapshot build is broken
Kevin Neufeld
kneufeld at refractions.net
Sun Mar 22 13:56:03 PDT 2009
Argh. Thanx for the heads up. Yup, it looks like SVN went down again.
At least the web site didn't go down as well. The reliability of the
hosting server is definitely getting to be a problem. Hmmm ... none of
the usual fixes seem to be working this time. I'll let you all know
when we've been able to restore services.
Thank-you all for your patience.
-- Kevin
codesite-noreply at google.com wrote:
> Comment #7 on issue 142 by mloskot: 1.4 snapshot build is broken
> http://code.google.com/p/postgis/issues/detail?id=142
> Trying to connect to SVN, I'm getting this error:
> mloskot at dog:~/dev/postgis/_svn$ svn co
> http://svn.refractions.net/postgis/trunk trunk
> svn: OPTIONS of 'http://svn.refractions.net/postgis/trunk': Could not
> read status
> line: Connection reset by peer (http://svn.refractions.net)
> You received this message because you are listed in the owner
> or CC fields of this issue, or because you starred this issue.
> You may adjust your issue notification preferences at:
> http://code.google.com/hosting/settings
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
