[postgis-devel] Issue 93 in postgis: ST_Extent() and ST_Estimated_Extent() return BOX2DFLOAT4s
codesite-noreply at google.com
Sun Mar 29 01:30:54 PDT 2009
Comment #5 on issue 93 by mark.cav... at siriusit.co.uk: ST_Extent() and
http://code.google.com/p/postgis/issues/detail?id=93
Ooops - looks like I was using the wrong version of postgis.sql for
testing :( Can
you test SVN trunk now?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
