[postgis-devel] Issue 93 in postgis: ST_Extent() and	ST_Estimated_Extent() return BOX2DFLOAT4s
    codesite-noreply at google.com
    Sat Mar 28 23:19:37 PDT 2009
Comment #4 on issue 93 by olivier.courtin: ST_Extent() and
http://code.google.com/p/postgis/issues/detail?id=93
Mark,
On PostgreSQL 8.3.7 postgis.sql load end on error.
  =>box2d function not yet defined in the new cast
I join a patch on postgis.sql.in.c who do the job on my box
And then with you're new cast, that's look good :
SELECT ST_XMAX(ST_Extent("surfaceProperty")::box2d)
FROM "PrimitiveGeoFeature";
45.8910026550293
SELECT ST_XMAX(ST_Extent("surfaceProperty")) FROM "PrimitiveGeoFeature";
45.891
Olivier
	DIFF_r3938  10.4 KB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
