[postgis-devel] Issue 93 in postgis: ST_Extent() and ST_Estimated_Extent() return BOX2DFLOAT4s
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 28 17:36:40 PDT 2009
Comment #3 on issue 93 by mark.cav... at siriusit.co.uk: ST_Extent() and
http://code.google.com/p/postgis/issues/detail?id=93
I've just committed the missing casts to trunk as r3938 which should
resolve the
issue. Please can you test?
ATB,
Mark.
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
