[postgis-devel] Issue 93 in postgis: ST_Extent() and ST_Estimated_Extent() return BOX2DFLOAT4s
codesite-noreply at google.com codesite-noreply at google.com
Sat Mar 28 12:17:18 PDT 2009
Comment #2 on issue 93 by olivier.courtin: ST_Extent() and
http://code.google.com/p/postgis/issues/detail?id=93
box3d_extent is not recognize by other Postgis function who already are
able to deal with box3d
SELECT ST_Extent("surfaceProperty") FROM "PrimitiveGeoFeature";
BOX(45.174 30.466,45.891 30.899)
SELECT ST_MAX(ST_Extent("surfaceProperty")) FROM "PrimitiveGeoFeature";
ERROR:  function st_max(box3d_extent) does not exist
SELECT ST_MAX(ST_Extent("surfaceProperty")::box2d)
ERROR:  cannot cast type box3d_extent to box2d
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
http://code.google.com/hosting/settings
