[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Sun Nov 22 10:47:25 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by colivier):
Regina,
You're right the install problem was the dual GEOS install.
I (finnaly) succeed to install the whole stuff with Mingw (not exactly a
piece of cake) !
With my install everything is fine with in_gml.sql and in_kml.sql
Postgis: r4813
Geos: 3.2.0 RC1
Libxml2: 2.7.6
I really suspect you're libxml2 installation to be the problem. Is it
possible for you (or someone else) to test it on an another box ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:12>
