[postgis-devel] [PostGIS] #273: ST_GeomFromGML crashes in Windows compiled in MingW
trac at osgeo.org
Sun Nov 22 17:53:15 PST 2009
Reporter: robe | Owner: colivier
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
Strange. Maybe its something else I install getting in the way or I'm not
compiling libxml right. I have another box I can try on later. Nicklas
-- you have a mingw install -- if its not asking too much -- can you try
compiling and doing the simple
SELECT
ST_GeomFromGML('<gml:Point><gml:coordinates>1,2</gml:coordinates></gml:Point>')
to see if it works.
Olivier - what is your mingw gcc and mingw/msys versions? On my gcc 3.5
box, I was able to compile and install without errors (except libxml make
checks fail), but got crashes when doing the above test. On my upgraded
mingw running gcc 4.4, I can't compile libxml at all.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/273#comment:13>
