[postgis-devel] [PostGIS] #324: ST_DumpPoints(geom, integer[]) is misnamed
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 30 08:59:29 PST 2009
Kevin Neufeld wrote:
> I think you can select just an interior ring if you know the ring's
> index ...
> SELECT path, ST_AsText(geom)
> FROM (
> SELECT (ST_DumpPoints(g.geom)).*
> FROM
> (SELECT
> 'POLYGON (( 3 0, 3 3, 6 3, 6 0, 3 0 ), ( 5 1, 4 2, 5 2, 5 1
> ))'::geometry AS geom
> ) AS g
> ) AS j;
WHERE path[1] = 2;
-- (Oops, forgot the WHERE clause)
> path | st_astext
> {2,1} | POINT(5 1)
> {2,2} | POINT(4 2)
> {2,3} | POINT(5 2)
> {2,4} | POINT(5 1)
> (4 rows)
> -- Kevin
>> Reporter: robe | Owner: kneufeld Type: defect
>> | Status: new Priority: medium | Milestone:
>> PostGIS 1.5.0
>> Component: postgis | Version: trunk Keywords:
>> We should either make this function do something cool or rename it to
>> _ST_DumpPoints.
>> The user in me was thinking
>> "Why does this function have no description? I wonder if the good
>> PostGIS
>> developers just forgot to document it. I wonder if I can extract the
>> points of an inner ring in a collection of a polygon by doing"
>> FROM (
>> SELECT (ST_DumpPoints(g.geom,ARRAY[4,2])).*
>> FROM
>> (SELECT
>> 'GEOMETRYCOLLECTION(
>> POINT ( 0 1 ),
>> LINESTRING ( 0 3, 3 4 ),
>> POLYGON (( 2 0, 2 3, 0 2, 2 0 )),
>> ( 5 1, 4 2, 5 2, 5 1 )),
>> MULTIPOLYGON (
>> (( 0 5, 0 8, 4 8, 4 5, 0 5 ),
>> ( 1 6, 3 6, 2 7, 1 6 )),
>> (( 5 4, 5 8, 6 7, 5 4 ))
>> ) AS g
>> ) AS j;
>> To my disappointment -- ehh you can't - its just a helper function
>> not a
>> navigation function.
