[postgis-devel] [PostGIS] #324: ST_DumpPoints(geom, integer[]) is misnamed
Kevin Neufeld
kneufeld at refractions.net
Mon Nov 30 08:51:18 PST 2009
I think you can select just an interior ring if you know the ring's index ...
SELECT path, ST_AsText(geom)
FROM (
SELECT (ST_DumpPoints(g.geom)).*
FROM
(SELECT
'POLYGON (( 3 0, 3 3, 6 3, 6 0, 3 0 ), ( 5 1, 4 2, 5 2, 5 1 ))'::geometry AS geom
) AS g
) AS j;
path | st_astext
{2,1} | POINT(5 1)
{2,2} | POINT(4 2)
{2,3} | POINT(5 2)
{2,4} | POINT(5 1)
(4 rows)
-- Kevin
> Reporter: robe | Owner: kneufeld
> Type: defect | Status: new
> Priority: medium | Milestone: PostGIS 1.5.0
> Component: postgis | Version: trunk
> Keywords: |
> We should either make this function do something cool or rename it to
> _ST_DumpPoints.
> The user in me was thinking
> "Why does this function have no description? I wonder if the good PostGIS
> developers just forgot to document it. I wonder if I can extract the
> points of an inner ring in a collection of a polygon by doing"
> FROM (
> SELECT (ST_DumpPoints(g.geom,ARRAY[4,2])).*
> FROM
> (SELECT
> 'GEOMETRYCOLLECTION(
> POINT ( 0 1 ),
> LINESTRING ( 0 3, 3 4 ),
> POLYGON (( 2 0, 2 3, 0 2, 2 0 )),
> ( 5 1, 4 2, 5 2, 5 1 )),
> MULTIPOLYGON (
> (( 0 5, 0 8, 4 8, 4 5, 0 5 ),
> ( 1 6, 3 6, 2 7, 1 6 )),
> (( 5 4, 5 8, 6 7, 5 4 ))
> ) AS g
> ) AS j;
> To my disappointment -- ehh you can't - its just a helper function not a
> navigation function.
