[postgis-devel] OGR support for SQL Server 2008
Mateusz Loskot
mateusz at loskot.net
Mon Nov 30 15:11:08 PST 2009
Mateusz Loskot wrote:
> Paragon Corporation wrote:
>> This is probably not the right forum, but figured I would ask anyway that
>> someone here might know. Does anyone know if there are plans in the works
>> to support SQL Server 2008 spatial in OGR2OGR and how far off that is if
>> there are plans.
> In case you look for simple solution, here is shp2pgsql equivalent :-)
> http://www.sharpgis.net/post/2007/12/23/Shapefile-to-SqlServer-2008-to-WPF.aspx
Quick google digged out direct port of shp2pgsql:
http://code.google.com/p/cumberland/wiki/shp2sqlserver
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
Charter Member of OSGeo, http://osgeo.org
