[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Fri Oct 2 14:23:12 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.3.X
Resolution: | Keywords:
Comment (by nicklas):
ok
I don't understand everything from the discussion above, but I have two
questions, that at least to me seems relevant :-)
If the problem is this RECHECK thing, why isn't it working as expected
from Paul's comment in r3287. I read it as he is putting that recheck flag
there, instead of in the operator class definition. If the recheck doesn't
work as expected I guess that's a good explanation of the unpredictable
behavior of the bug from Paul's comment that it is the conversion from
float8 to float4 that makes it nessecary. But at the other side I think
that should only cause a little bit to many true-answers (because all
boxes is rounded to be a little bigger) for the bbox-comparation. Why does
it make the planner choose not to do the vertex to vertex comparasion.
the second question, can this recheck-thing explain that there is
different answer between select-part and where-part of the query. That
part of the issue worries me a bit.
and the third unannounced question.
Do we (read you) have control that no other functions are affected so we
don't just hide the symtom instead of finding the cause.
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:26>
