[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Fri Oct 2 18:14:47 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.3.X
Resolution: | Keywords:
Comment (by robe):
The reason why its different in the WHERE from the SELECT part is that the
indexed calculation is only used in WHERE (the index doesn't kick in on
the SELECT)
Since GIST is lossy (basically only works against the bbox) and ~= was not
meant to be, the GIST answer is just bbox compare. What the RECHECK does
is say if the index answer returns true, check the real value. Without
the RECHECK, it would accept the answer of the index which in this case is
wrong. So the compare based on index would just be checking the 4 numbers
of the bbox.
the float4, float8 issue I haven't thought of, but that would cause the
situation where the index answer is wrong even for a bbox case I guess.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:27>
