[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Fri Oct 2 23:20:00 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.3.X
Resolution: | Keywords:
Comment (by nicklas):
now I'm little confused. I thought I found this as a special case, because
I had to struggle to minimize the dataset without destroying the error.
[[BR]]
If you try se same thing at testcase2 it will work as expected and return
nothing and the only difference is that I took away one of the other
polygons and ran vacuum full analyze on it.[[BR]]
[[BR]]
But now I see that it maybe is the planner that is cheating me. on
testcase2 it[[BR]] doesn't seem to use the index:[[BR]]
it seems like the change in behavior is because the planner decides the
dataset is too small for using the index. Am I right?
/Nicklas
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:28>
