[postgis-devel] [PostGIS] #253: Gist causes wrong result from ~=
trac at osgeo.org
Sat Oct 3 05:55:46 PDT 2009
Reporter: nicklas | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: postgis 1.4.1
Component: postgis | Version: 1.3.X
Resolution: | Keywords:
Comment (by robe):
That sounds about right. If the planner doesn't use the index you should
see the behavior you expect whereas when it does -- it will use the bboxes
from the index to satisfy the WHERE and the geometry from the table to
satisfy the SELECT.
not all databases behave this way by the way and PostgreSQL may change
later to implement covered indexes the way say SQL Server does so that the
index value may also be used if you mark the answer as not lossy (so it
never needs to hit the table). In that case the difference will be
totally camouflaged and harder to troubleshoot.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/253#comment:29>
