[postgis-devel] fix for memory leaks in shp2pgsql.c
Paul Ramsey
pramsey at cleverelephant.ca
Tue Oct 13 16:24:56 PDT 2009
Maybe I just dreamed about fixing it. Or maybe I fixed something
egregious and left behind something less noticeable in my use case.
On Tue, Oct 13, 2009 at 4:11 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
> Paul,
> 1.4.0.
> I originally hit the problem on 1.3.x, then patched 1.4.0, which
> I'm /pretty/ sure was exhibiting the problem.
> It was easy to see in `top` that shp2pgsql was gorging on memory as
> execution continued, and the leak locations were revealed fairly
> clearly in `valgrind --leak-check=full`. This work is all against
> polygons; my impression is that loading of points or linestrings is
> unaffected.
> -Dave
> On Tue, Oct 13, 2009 at 5:32 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Huh, what version is this against? I thought I had cleaned those out.
>> P.
>> On Tue, Oct 13, 2009 at 2:21 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>>> This patch fixes memory leaks in shp2pgsql.c.
>>> Previously, loading a 1.5GB shapefile was running a 4GB machine out of memory.
>>> -Dave
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
