[postgis-devel] fix for memory leaks in shp2pgsql.c
Chris Hodgson
chodgson at refractions.net
Tue Oct 13 16:31:42 PDT 2009
Paul, this fix looks like it is specifically for large multi-polygon
collections, perhaps your original test cases didn't include such data?
I do recall you reporting having fixed "all" the memory leak issues
before, but if you didn't have any multi-polygons in your test data then
I could see how this would have been missed.
Chris
Paul Ramsey wrote:
> Maybe I just dreamed about fixing it. Or maybe I fixed something
> egregious and left behind something less noticeable in my use case.
> On Tue, Oct 13, 2009 at 4:11 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>> Paul,
>> 1.4.0.
>> I originally hit the problem on 1.3.x, then patched 1.4.0, which
>> I'm /pretty/ sure was exhibiting the problem.
>> It was easy to see in `top` that shp2pgsql was gorging on memory as
>> execution continued, and the leak locations were revealed fairly
>> clearly in `valgrind --leak-check=full`. This work is all against
>> polygons; my impression is that loading of points or linestrings is
>> unaffected.
>> -Dave
>> On Tue, Oct 13, 2009 at 5:32 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>>> Huh, what version is this against? I thought I had cleaned those out.
>>> P.
>>> On Tue, Oct 13, 2009 at 2:21 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>>>> This patch fixes memory leaks in shp2pgsql.c.
>>>> Previously, loading a 1.5GB shapefile was running a 4GB machine out of memory.
>>>> -Dave
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
