[postgis-devel] fix for memory leaks in shp2pgsql.c
Dave Fuhry dfuhry at gmail.com
Tue Oct 13 16:47:57 PDT 2009
You can get the smaller of the test files I used here:
http://reportallusa.com/tmp/natwatershedlow.zip
It's 325MB uncompressed.
-Dave
On Tue, Oct 13, 2009 at 7:31 PM, Chris Hodgson <chodgson at refractions.net> wrote:
> Paul, this fix looks like it is specifically for large multi-polygon
> collections, perhaps your original test cases didn't include such data? I do
> recall you reporting having fixed "all" the memory leak issues before, but
> if you didn't have any multi-polygons in your test data then I could see how
> this would have been missed.
> Chris
> Paul Ramsey wrote:
>> Maybe I just dreamed about fixing it. Or maybe I fixed something
>> egregious and left behind something less noticeable in my use case.
>> On Tue, Oct 13, 2009 at 4:11 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>>> Paul,
>>>  1.4.0.
>>>  I originally hit the problem on 1.3.x, then patched 1.4.0, which
>>> I'm /pretty/ sure was exhibiting the problem.
>>>  It was easy to see in `top` that shp2pgsql was gorging on memory as
>>> execution continued, and the leak locations were revealed fairly
>>> clearly in `valgrind --leak-check=full`.  This work is all against
>>> polygons; my impression is that loading of points or linestrings is
>>> unaffected.
>>> -Dave
>>> On Tue, Oct 13, 2009 at 5:32 PM, Paul Ramsey <pramsey at cleverelephant.ca>
>>> wrote:
>>>> Huh, what version is this against? I thought I had cleaned those out.
>>>> P.
>>>> On Tue, Oct 13, 2009 at 2:21 PM, Dave Fuhry <dfuhry at gmail.com> wrote:
>>>>> This patch fixes memory leaks in shp2pgsql.c.
>>>>> Previously, loading a 1.5GB shapefile was running a 4GB machine out of
>>>>> memory.
>>>>> -Dave
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
