[postgis-devel] Geog/Geom Hack
Paul Ramsey
pramsey at cleverelephant.ca
Fri Oct 30 17:33:37 PDT 2009
I'm not sure I understand why you would ever convert a geometry to a
geography as part of a query on a geometry table. I fully expect
geography to be used as a storage type, because of the utility of
having the correct spherical indexes, which are not available when
you're just converting in via a cast. Since there's no functions
available on geography that are not already available on geometry, why
would you ever do a geometry->geography cast unless you are (a)
testing geography or (b) bulk converting a table into geography for
storage in that type.
P.
On Fri, Oct 30, 2009 at 5:24 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Paul,
> I would rather you didn't for 2 reasons
> 1) I'm lazy and for each of these things we'd have to apply the text
> additional function proto hack to prevent from it breaking geometry. which
> we will probably end up taking out anyway.
> 2) I don't like the hiddenness of it since it becomes especially annoying if
> you have your native in geometry and you are converting to geography for a
> special usecase, then you end up with a slower implementation
> as you would really end up doing accidentally
> geometry -> geography -> geometry ->operation (and why do I want my calcs
> done in UTM?)
> Instead of the more efficient
> geometry -> operation
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Friday, October 30, 2009 8:16 PM
> To: PostGIS Development Discussion
> Subject: [postgis-devel] Geog/Geom Hack
> I'm interested to know what the general opinion is of the trick I've used on
> ST_Buffer(geography):
> http://trac.osgeo.org/postgis/browser/trunk/postgis/geography.sql.in.c#L541
> I ask because I could apply the same idea to the larger suite of OGC SFSQL
> predicates before release. Is half-a-loaf better than no loaf in this case?
> (Note that there will be failure cases for really large geometry, like a
> polygon of "Asia" or "Russia" that have polygons over the dateline.)
> P.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
