[postgis-devel] regression-tests failing on ubuntu 64 on trunk
    Nicklas Avén
    nicklas.aven at jordogskog.no
    Mon Aug  2 14:03:16 PDT 2010
I get failed regression-tests on trunk
I get 5 failed tests on ubuntu 64, but all looks good in windows.
postgis-1.5.1 passes all tests on same ubuntu-box
I attach the log
/Nicklas
 PostgreSQL 8.4.4 on x86_64-pc-linux-gnu, compiled by GCC gcc-4.4.real
(Ubuntu 4.4.3-4ubuntu5) 4.4.3, 64-bit
 Postgis 2.0.0SVN - 2010-08-02 20:40:38
   GEOS: 3.3.0-CAPI-1.7.0
   PROJ: Rel. 4.7.1, 23 September 2009
Running tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. failed (diff expected
obtained: /tmp/pgis_reg_28113/test_13_diff)
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. failed (diff expected obtained: /tmp/pgis_reg_28113/test_23_diff)
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. failed (diff expected
obtained: /tmp/pgis_reg_28113/test_29_diff)
 sql-mm-curvepoly. failed (diff expected
obtained: /tmp/pgis_reg_28113/test_30_diff)
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 out_geometry. ok
 out_geography. ok
 in_gml. ok
 in_kml. ok
 iscollection. ok
 regress_ogc. ok
 regress_ogc_cover. ok
 regress_ogc_prep. ok
 regress_bdpoly. ok
 regress_proj. ok
 dumppoints. ok
 wmsservers. ok
 tickets. failed (diff expected
obtained: /tmp/pgis_reg_28113/test_46_diff)
 remove_repeated_points. ok
 split. ok
 regress_buffer_params. ok
 hausdorff. ok
 clean. ok
Run tests: 51
Failed: 5
Type: application/x-compressed-tar
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100802/06ee4616/attachment.bin>
