[postgis-devel] regression-tests failing on ubuntu 64 on trunk
Mateusz Loskot
mateusz at loskot.net
Tue Aug 3 06:48:58 PDT 2010
On 03/08/10 14:41, Nicklas Avén wrote:
> I have double checked, It works in windows but fails in Ubuntu 64.
> The problem comes with r5753 the add of POLYHEDRALSURFACE support
> http://trac.osgeo.org/postgis/changeset/5753
Today morning, I did complete rebuild, installation and regression of:
GEOS (SVN/trunk)
PostGIS (SVN/trunk)
WKT Raster (SVN/spike)
and I didn't notice any tests failing for any of the three components.
I run it on Linux 64-bit (Ubuntu 10.4) with PostgreSQL 8.4.
Thankfully, I have all the 3 terminal windows still open, so here we go:
=== GEOS ==============================================================
make[3]: Entering directory `/home/mloskot/dev/geos/_svn/trunk/tests/unit'
GEOS Test Suite Application
capi::GEOSBuffer: ..................
capi::GEOSContains: ...
capi::GEOSCoordSeq: ......
capi::GEOSGeomFromWKB: .....
capi::GEOSGeomToWKT: .............
capi::GEOSGeom_create: .......
capi::GEOSGeom_extractUniquePoints: ...
capi::GEOSLineStringPoint: ...
capi::GEOSOrientationIndex: ...........
capi::GEOSPolygonizeGetCutEdges: ..
capi::GEOSPreparedGeometry: ....
capi::GEOSSimplify: .
capi::GEOSWithin: ...
geos::algorithm::CGAlgorithms::computeOrientation: ..
geos::algorithm::CGAlgorithms::isCCW: ...
geos::algorithm::CGAlgorithms::isPointInRing: ..
geos::algorithm::ConvexHull: .......
geos::algorithm::PointLocator: ....
geos::algorithm::RobustLineIntersection: ..
geos::algorithm::RobustLineIntersector: .............
geos::algorithm::distace::DiscreteHausdorffDistance: ....
geos::geom::Coordinate: .........
geos::geom::CoordinateArraySequence: ................
geos::geom::CoordinateArraySequenceFactory: ....
geos::geom::CoordinateList: .
geos::geom::Dimension: .....
geos::geom::Envelope: .........
geos::geom::Geometry::covers: ...
geos::geom::Geometry::isRectangle: .......
geos::geom::GeometryFactory: ...................................
geos::geom::IntersectionMatrix: .............................
geos::geom::LineSegment: ......
geos::geom::LineString: .........................
geos::geom::LinearRing: ..............................
geos::geom::Location: ...
geos::geom::MultiLineString: .
geos::geom::MultiPoint: ............................
geos::geom::MultiPolygon: .
geos::geom::Point: ........................................
geos::geom::Polygon: .....................................
geos::geom::Triangle: .....
geos::geom::prep::PreparedGeometryFactory: .............................
geos::index::quadtree::DoubleBits: .
geos::io::ByteOrderValues: ...
geos::io::WKBReader: .......
geos::io::WKBWriter: ...
geos::io::WKTReader: ......
geos::io::WKTWriter: ....
geos::linearref::LocationIndexedLine: ........................
geos::noding::BasicSegmentString: ....
geos::noding::NodedSegmentString: .....
geos::noding::SegmentNode: ....
geos::noding::SegmentPointComparator: .
geos::operation::IsSimpleOp: ...
geos::operation::buffer::BufferOp: .........
geos::operation::distance::DistanceOp: ..................
geos::operation::geounion::CascadedPolygonUnion: .
geos::operation::overlay::snap::GeometrySnapper: ..
geos::operation::overlay::snap::LineStringSnapper: ..
geos::operation::overlay::validate::FuzzyPointLocator: .......
geos::operation::overlay::validate::OffsetPointGenerator: .....
geos::operation::overlay::validate::OverlayResultValidator: ......
geos::operation::valid::IsValidOp: .
geos::operation::valid::ValidClosedRing: .....
geos::operation::valid::ValidSelfTouchingRingFormingHole: .......
geos::precision::SimpleGeometryPrecisionReducer: .......
geos::simplify::DouglasPeuckerSimplifier: ..........
geos::simplify::TopologyPreservingSimplifier: ..........
geos::util::UniqueCoordinateArrayFilter: .
tests summary: ok:595
PASS: geos_unit
1 test passed
make[3]: Leaving directory `/home/mloskot/dev/geos/_svn/trunk/tests/unit'
=== PostGIS ========================================================
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_469
PATH is :/home/mloskot/bin:/home/mloskot/bin:/usr/local/sbin:/usr/local/bi
PostgreSQL 8.4.4 on x86_64-pc-linux-gnu, compiled by GCC gcc-4.4.real (Ub
Postgis 2.0.0SVN - 2010-08-03 10:34:03
GEOS: 3.3.0-CAPI-1.7.0
PROJ: Rel. 4.7.1, 23 September 2009
Running tests
loader/Point.............. ok
loader/PointM.............. ok
loader/PointZ.............. ok
loader/MultiPoint.............. ok
loader/MultiPointM.............. ok
loader/MultiPointZ.............. ok
loader/Arc.............. ok
loader/ArcM.............. ok
loader/ArcZ.......... ok
loader/Polygon.............. ok
loader/PolygonM.............. ok
loader/PolygonZ.............. ok
regress. ok
regress_index. ok
regress_index_nulls. ok
lwgeom_regress. ok
regress_lrs. ok
removepoint. ok
setpoint. ok
simplify. ok
snaptogrid. ok
affine. ok
wkt. ok
measures. ok
long_xact. ok
ctors. ok
sql-mm-serialize. ok
sql-mm-circularstring. ok
sql-mm-compoundcurve. ok
sql-mm-curvepoly. ok
sql-mm-general. ok
sql-mm-multicurve. ok
sql-mm-multisurface. ok
out_geometry. ok
out_geography. ok
in_gml. ok
in_kml. ok
iscollection. ok
regress_ogc. ok
regress_ogc_cover. ok
regress_ogc_prep. ok
regress_bdpoly. ok
regress_proj. ok
dumppoints. ok
wmsservers. ok
tickets. ok
remove_repeated_points. ok
split. ok
regress_buffer_params. ok
hausdorff. ok
clean. ok
Run tests: 51
Failed: 0
make[1]: Leaving directory `/home/mloskot/dev/postgis/_svn/trunk/regress'
=== WKT Raster =====================================================
Creating spatial db rtpostgis_reg
TMPDIR is /tmp/rtpgis_reg_5787
(Ubuntu 4.4.3-4ubuntu5) 4.4.3, 64-bit
WKTRaster 0.1.6d - 2010-08-03 10:39:10
Running tests
rt_io. ok
create_rt_bytea_test. ok
rt_bytea. ok
create_rt_box2d_test. ok
rt_box2d. ok
create_rt_properties_test. ok
rt_dimensions. ok
rt_pixelsize. ok
rt_upperleft. ok
rt_rotation. ok
rt_georeference. ok
rt_set_properties. ok
create_rt_band_properties_test. ok
rt_band_properties. ok
rt_set_band_properties. ok
rt_pixelvalue. ok
create_rt_utility_test. ok
rt_utility. ok
create_rt_gist_test. ok
rt_above. ok
rt_below. ok
rt_contained. ok
rt_contain. ok
rt_left. ok
rt_overabove. ok
rt_overbelow. ok
rt_overlap. ok
rt_overleft. ok
rt_overright. ok
rt_right. ok
rt_same. ok
rt_spatial_relationship. ok
bug_test_car5. ok
Run tests: 33
Failed: 0
make[2]: Leaving directory
`/home/mloskot/dev/wktraster/_svn/trunk/test/regress'
Best regards,
Mateusz Loskot, http://mateusz.loskot.net
