[postgis-devel] regression-tests failing on ubuntu 64 on trunk
Nicklas Avén nicklas.aven at jordogskog.no
Tue Aug 3 06:41:30 PDT 2010
I have double checked, It works in windows but fails in Ubuntu 64.
The problem comes with r5753 the add of POLYHEDRALSURFACE support
http://trac.osgeo.org/postgis/changeset/5753
/Nicklas
On Tue, 2010-08-03 at 09:32 +0100, Mark Cave-Ayland wrote:
> Nicklas Avén wrote:
> > I get failed regression-tests on trunk
> > I get 5 failed tests on ubuntu 64, but all looks good in windows.
> > postgis-1.5.1 passes all tests on same ubuntu-box
> > I attach the log
> > /Nicklas
> Hmmm looks like the issue is that the parser code in
> liblwgeom/lwgparse.c thinks that the detected error position has changed.
> Are you sure that you did a complete rebuild on both platforms,
> including a "make clean" to do a rebuild of liblwgeom? I can understand
> that the parse position could change, but if it did then it should
> affect all platforms and not just one.
> Can you narrow it down using an SVN bisect?
> ATB,
> Mark.
