[postgis-devel] [PostGIS] #555: Ability to define a geometry column as Polyhedral surface
PostGIS trac at osgeo.org
Fri Aug 6 04:39:36 PDT 2010
 Reporter:  robe     |       Owner:  colivier
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 We'll also want to put a new in this release too.  No need to worry about
 that though.  I'll flag them as I come across them in my testing and
 confirm with you that they really are supposed to work.  I'll aslo add
 another matrix column (though what to call that column) ?
 Might be easier to just see which functions when subjected to polyhedral
 surfaces the garden tester arrives at an answer for which is the reason
 for enhancing the subtests to isolate certain kinds of geometries. Should
 be interesting.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/555#comment:5>
