[postgis-devel] closed surfaces, volum or just closed surface
Nicklas Avén
nicklas.aven at jordogskog.no
Tue Aug 17 05:00:22 PDT 2010
Great,
just wanted to calibrate the thinking :-)/Nicklas
2010-08-17 Olivier Courtin wrote:
>On Aug 17, 2010, at 1:35 PM, Nicklas Avén wrote:
>Nicklas,
>> in #568 you write:
>> "As a consequence closed surface (so volume) have a 0 perimeter
>> value return"
>> Is it so. Isn't it nessecary to be able to describe a closed survace
>> without handling it as a volum or polyhedron?
>> I mean like a closed linestring. Sometimes you just want a closed
>> linestring not a polygon.
>> I thought this was to opff topic in #568 so I put it in a separate
>> post.
>> Does the spec say anything about this?
>Well in fact in ISO 19107 we have all the kind of geometries we could
>dream in GIS field fully describded.
>And so we've got points, curves, surfaces, solids, conic and so on...
>Right now this full model is really ambitous.
>(This model is also used in GML 3, and so in CityGML)
>Current spatial databases standard only take a part of it.
>(Even if we have strong clues that the next one will take in count
>the full ISO 19107 model.)
>And in fact PolyhedralSurface or TIN are initialy surfaces.
>So by analogy they behave more like your linestring (who could be
>closed).
>And still by analogy your polygon equivalent in 3D is a solid
>in ISO 19107, but there's still no database standard to describe it.
>So the best we have right now (in spatial database standards) is 3D
>closed surface...
>> The difference shows for example when we measure distance from a
>> closed survace/volum
>> to a point inside it. If it is a volum the distance is 0 if it is
>> just a closed surface there is a distance
>> to calculate to the closest facet.
>I'm agree with you that's a really good idea to have
>a flag to indicate on the geometry if it's closed or not (volume or
>surface)
>I've just began to think on a topology serialization,
>need to work on it far more...
>Olivier
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100817/bf678779/attachment.html>
