[postgis-devel] [PostGIS] #577: possible memory leak with buffer()
trac at osgeo.org
Sat Aug 21 09:01:04 PDT 2010
Reporter: davideps | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 1.3.X
Keywords: memory buffer intersect dwithin |
Changes (by robe):
* owner: pramsey => robe
Comment:
David,
I don't think this is a bug, and if it is its probably in an already
patched GEOS. Before I dismiss this as a non-issue, can you tell us which
version of GEOS you are running? The below query will tell you.
SELECT postgis_full_version();
Secondly doing a buffer takes a lot of memory because it has to create a
derivative geometry. The more points in your geometry the more memory it
will take.
Thirdly there have been memory leaks in prior GEOS versions that have
since been patched. Some having to do with buffer. If you are running
GEOS below 3.2, you might want to upgrade your GEOS.
Forthly do you have spatial indexes in place as Nicklas had mentioned? 22
minutes is still quite a bit of time, though may be valid for your query
set.
Thanks,
Regina
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:1>
