[postgis-devel] [PostGIS] #577: possible memory leak with	buffer()
    trac at osgeo.org
    Sat Aug 21 09:03:40 PDT 2010
 Reporter:  davideps                         |       Owner:  robe
     Type:  defect                           |      Status:  new
 Priority:  medium                           |   Milestone:
Component:  postgis                          |     Version:  1.3.X
 Keywords:  memory buffer intersect dwithin  |
Comment(by robe):
 Forgot to mention that ST_DWithin does not need to create a derivative
 geometry since it uses distance and short-circuit distance calcs.  This is
 why the memory of that would be much less for what you are doing.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:2>
