[postgis-devel] [PostGIS] #577: possible memory leak with	buffer()
    trac at osgeo.org
    Sat Aug 21 09:37:59 PDT 2010
 Reporter:  davideps                         |       Owner:  robe
     Type:  defect                           |      Status:  new
 Priority:  medium                           |   Milestone:
Component:  postgis                          |     Version:  1.3.X
 Keywords:  memory buffer intersect dwithin  |
Comment(by davideps):
 Hi Regina,
 VERSION INFO:
 "POSTGIS="1.3.3" GEOS="3.1.1-CAPI-1.6.0" PROJ="Rel. 4.7.1, 23 September
 2009" USE_STATS"
 Do I upgrade GEOS separately or do I need to upgrade postgis as well?
 I have a GIST index on the geometry. How quickly would you expect a decent
 laptop to calculate
 dwithin on 320,000 polygons? It is difficult for me to judge performance.
 thank you,
 -david
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:3>
