[postgis-devel] [PostGIS] #577: possible memory leak with buffer()
trac at osgeo.org
Sat Aug 21 09:53:51 PDT 2010
Reporter: davideps | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone:
Component: postgis | Version: 1.3.X
Resolution: invalid | Keywords: memory buffer intersect dwithin
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
David,
Those particular questions should be asked on PostGIS users list since
they are not bugs.
For upgrading GEOS 3.1 is more or less fine when using 1.3. I don't think
you'll gain much. In theory you can get away with just upgrading GEOS
without PostGIS as long as your symlinks are appropriately set (since GEOS
3.2 (superset) is a drop in replace for 3.1)
As with most things, it depends. It depends on the complexity of your
geometries, the area of the polygons, how close they are together etc. It
could be anywhere from milliseconds to minutes depending on those factors
and not knowing the details we can't give you an answer.
I've run queries (as most people have) on much larger polygon sets and
they finish in a fraction of a second (then again the number of records in
those cases is probably about 100-1000 for results or so and I chop up my
polygons if they get too large or simplify them so they have fewer points
when speed becomes an issue)
You really need to do an EXPLAIN (faster but less detailed) or an EXPLAIN
ANALYZE (takes about same time as your query minus time to output, but
gives more detail) your query.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/577#comment:4>
