[postgis-devel] [PostGIS] #578: PostGIS Box2D (and && operator) gives wrong result for ST_CircularString type
    trac at osgeo.org
    Mon Aug 30 03:33:08 PDT 2010
type
 Reporter:  vince           |       Owner:  pramsey
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 1.5.2
Component:  postgis         |     Version:  trunk
 Keywords:  Box2D ST_Curve  |
 Box2D is supposed to support ST_Curve types, but obviously, albeit calling
 Box2D with an ST_CircularString causes no error, the returned box is
 wrong. See three cases in the SQL sample file attached (circle, half-
 circle, "half-infinity" glyph).
 Consequently, the && operator is also buggy, which prevent spatial queries
 to work reliably.
 Seems same bugs exist in trunk (tested by Olivier Courtin, OsLandia).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/578>
