[postgis-devel] [PostGIS] #674: PostgreSQL 9.1 aggregation error
PostGIS trac at osgeo.org
Wed Dec 1 17:28:20 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
 This only seems to fail in my 9.1 alpha1 build.  I'm trying to think the
 last time I tested my garden tests on 9.1.  I'm going to test my older
 binaries to see if they work or not and report back.
 Anyrate:
 SELECT ST_Collect(geom)  As the_geom
                 FROM (VALUES (
 ST_GeomFromEWKT('SRID=4326;MULTIPOLYGON(((-71.0821 42.3036 2,-71.0822
 42.3036 2,-71.082 42.3038 2,-71.0819 42.3037 2,-71.0821 42.3036 2)))') ),
         ( ST_GeomFromEWKT('SRID=4326;POLYGON((-71.1261 42.2703 1,-71.1257
 42.2703 1,-71.1257 42.2701 1,-71.126 42.2701 1,-71.1261 42.2702 1,-71.1261
 42.2703 1))') )
                 )       As g(geom) CROSS JOIN generate_series(1,3) As i
                 GROUP BY i;
 On my 9.1 Alpha1 VC++ windows build fails with:
 ERROR:  array_agg_transfn called in non-aggregate context
 ********** Error **********
 SQL state: XX000
 I think its a bug in our code, because I can do this:
 SELECT array_agg(1) As dummy_one
                 FROM (VALUES (
 42.2703 1))') )
                 GROUP BY i
Ticket URL: <http://trac.osgeo.org/postgis/ticket/674>
