[postgis-devel] [PostGIS] #670: ST_SharedPaths
PostGIS trac at osgeo.org
Fri Dec 3 14:59:18 PST 2010
  Reporter:  strk     |       Owner:  strk
      Type:  defect   |      Status:  closed
  Priority:  high     |   Milestone:  PostGIS 2.0.0
 Component:  postgis  |     Version:  trunk
Resolution:  fixed    |    Keywords:
Changes (by robe):
  * status:  reopened => closed
  * resolution:  => fixed
Comment:
 Strk,
 I'm going to assume you are right and close this out for now.  All my
 problems are pointing squarely at Paul :)
 Its like my install script is just installing the .sql files and not the
 .dlls (its hard to tell since my script builds for 3 versions of
 postgresql so I'll have to walk thru it).  I haven't confirmed yet (the
 dates look new but).  The tell-tale signs of new script old dlls behavior
 seem to match up too nicely. That would explain the ST_Snap issue as well.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/670#comment:13>
