[postgis-devel] [PostGIS] #688: ST_Contains POLYGON Empty with real linestring crash
trac at osgeo.org
Wed Dec 8 13:50:27 PST 2010
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
SELECT
ST_Contains(ST_GeomFromText('LINESTRING(-10 50,50 -10,4326
ST_GeomFromText('POLYGON EMPTY',4326));
-- the actual query that crashed -- teh above is a distilled subset but
there may be more monsters lurking in this query
SELECT ST_Contains(foo1.the_geom, foo2.the_geom) As result,
ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
ref2_geom
FROM ((SELECT
ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))
As the_geom
FROM generate_series(-10,50,10) As i
CROSS JOIN generate_series(50,70, 20) As j
CROSS JOIN generate_series(1,2) As m
WHERE NOT(i = j)
ORDER BY i, j, m, i*j*m)) As foo1 CROSS JOIN
((SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom
UNION ALL SELECT ST_GeomFromText('POLYGON
UNION ALL SELECT ST_GeomFromText('POINT
UNION ALL SELECT ST_GeomFromText('MULTIPOINT
UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
UNION ALL SELECT ST_GeomFromText('LINESTRING
UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
EMPTY',4326) As the_geom ) ) As foo2
Ticket URL: <http://trac.osgeo.org/postgis/ticket/688>
