[postgis-devel] [PostGIS] #688: ST_Contains POLYGON Empty with real linestring crash
PostGIS trac at osgeo.org
Wed Dec 8 13:56:03 PST 2010
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Description changed by robe:
Old description:
> SELECT
> ST_Contains(ST_GeomFromText('LINESTRING(-10 50,50 -10,4326
> ST_GeomFromText('POLYGON EMPTY',4326));
> -- the actual query that crashed -- teh above is a distilled subset but
> there may be more monsters lurking in this query
> SELECT ST_Contains(foo1.the_geom, foo2.the_geom) As result,
> ST_AsText(foo1.the_geom) As ref1_geom, ST_AsText(foo2.the_geom) As
> ref2_geom
>         FROM ((SELECT
> ST_MakeLine(ST_SetSRID(ST_MakePointM(i,j,m),4326),ST_SetSRID(ST_MakePointM(j,i,m),4326))
> As the_geom
>                 FROM generate_series(-10,50,10) As i
>                         CROSS JOIN generate_series(50,70, 20) As j
>                         CROSS JOIN generate_series(1,2) As m
>                         WHERE NOT(i = j)
>                         ORDER BY i, j, m, i*j*m)) As foo1 CROSS JOIN
> ((SELECT ST_GeomFromText('GEOMETRYCOLLECTION EMPTY',4326) As the_geom
>                         UNION ALL SELECT ST_GeomFromText('POLYGON
>                         UNION ALL SELECT ST_GeomFromText('POINT
>                         UNION ALL SELECT ST_GeomFromText('MULTIPOINT
>                         UNION ALL SELECT ST_GeomFromText('MULTIPOLYGON
>                         UNION ALL SELECT ST_GeomFromText('LINESTRING
>                         UNION ALL SELECT ST_GeomFromText('MULTILINESTRING
> EMPTY',4326) As the_geom ) ) As foo2
New description:
 SELECT
 ST_Contains(ST_GeomFromText('LINESTRING(-10 50,50 -10)',4326),
 The above doesn't always crash the first time but does after second or
 third call.
 -- the actual query that crashed -- the above is a distilled subset but
 ref2_geom
         FROM ((SELECT
 As the_geom
                         WHERE NOT(i = j)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/688#comment:1>
