[postgis-devel] [PostGIS] #160: prefix not recognized in 1.4.0SVN
trac at osgeo.org
Sat Feb 13 13:06:25 PST 2010
Reporter: kneufeld | Owner: mcayland
Type: defect | Status: closed
Priority: low | Milestone: PostGIS 1.4.0
Component: postgis | Version: 1.4.X
Resolution: wontfix | Keywords:
Changes (by rpriedhorsky):
* version: => 1.4.X
Comment:
Mark, DESTDIR only sort of works. I tried (with 1.4.1):
$ PATH=/usr/lib/postgresql/8.2/bin:/export/scratch/reid/geos/bin:$PATH
./configure --prefix=/export/scratch/reid/postgis-1.4/ --with-
geos=/export/scratch/reid/geos/bin/geos-config --with-
pgsql=/usr/lib/postgresql/8.2/bin/pg_config
DESTDIR=/export/scratch/reid/postgis-1.4
$ make DESTDIR=/export/scratch/reid/postgis-1.4
$ make install DESTDIR=/export/scratch/reid/postgis-1.4
The install indeed writes to /export/scratch/reid/postgis-1.4, but it then
also includes a bunch of unwanted additional directories below that. I
haven't yet tested it, but I assume I can clean up the junk with some
additional scripting.
Is the situation any different in 1.5? I didn't see anything in the
release notes.
Can you please reopen this bug and boost the priority? This is non-
standard configure behavior, and a regression.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/160#comment:11>
