[postgis-devel] [WKTRaster] Setting properties on a raster
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Sun Feb 21 11:26:10 PST 2010
>I'm looking at setting the properties of a raster. I managed to
>figure out how to set the SRID pretty easily:
>http://trac.osgeo.org/postgis/ticket/423
This is very great Zwarg!
>I'm thinking about ST_SetPixelType now, and I'm wondering how you want
>to handle the data conversions. It seems like when the pixel type is
>changed, the raster data will need to be processed and either
>truncated or re-allocated, as the pixel type is changed. Is that
>correct?
>A also noticed that ST_SetWidth and ST_SetHeight are not in the spec,
>is that intentional? Would it ever make sense to set the height and
>the width? In one sense, ST_SetPixelType is performing the same kind
>of truncation/expansion on the bit depth as ST_SetWidth/ST_SetHeight
>would perform the truncation/expansion in the spatial dimension.
>Should ST_SetPixelType be dropped if ST_SetWidth and ST_SetHeight are
>not implemented? Or should ST_SetHeight and ST_SetWidth be
>implemented as well?
I agree that ST_SetPixelType does not really make sence... If I want to change the pixel type I would probably instead want to do something like:
ST_MapAlgebra(raster, 'int(A)') on a float raster or ST_MapAlgebra(raster, 'float(A)') on a integer raster...
Pierre
