[postgis-devel] Another Styling Possibility?
Paul Ramsey
pramsey at cleverelephant.ca
Mon Feb 22 06:24:49 PST 2010
Not only to run make astyle, but to do so using the "blessed" version,
since we have now discovered that all versions produce slightly
different output. Could be beyond annoying.
P
On Mon, Feb 22, 2010 at 6:05 AM, Maxime van Noppen <maxime at altribe.org> wrote:
> On 02/22/2010 03:01 PM, Paul Ramsey wrote:
>> I just read up on svn hooks, and it doesn't support hooks that alter
>> the input, only ones that accept/reject the commit and have
>> side-effects (like posting to a mail list or irc or whatever).
>> Jeff had a suggestion, which was to use a hudson process that, on each
>> commit, runs astyle and commits any format changes. This would neatly
>> separate code changes from format changes in the commits, which would
>> be nice.
> What about having a hook that rejects the commit if it is not correctly
> formatted ? This would "force" the developers to remember to run 'make
> astyle' before committing though it might be annoying.
> Maxime
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
