[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
PostGIS trac at osgeo.org
Sat Jan 9 01:04:22 PST 2010
  Reporter:  pramsey  |       Owner:  mcayland
      Type:  defect   |      Status:  reopened
  Priority:  medium   |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Changes (by robe):
  * status:  closed => reopened
  * resolution:  fixed =>
Comment:
 Okay finally got around to testing and testing the 1.50.b1.  This doesn't
 quite work.
 It puts the .sql files in the right place and installs the loader exes,
 but it never installs postgis-1.5.dll (though I do see it built as
 libpostgis-1.5.dll and sitting in the postgis source folder).
 Is there a hard-coding somewhere.  I got this notice during configure and
 I don't even have my mingw compiled postgres 8.3 in /usr/local/pgsql/8.3
 but I do have all those paths in my /c/postgres83/lib folder so why on
 earth is it looking at that location.
 make[1]: Entering directory `/c/thesrc/postgis-1.5.0b1/postgis'
 Makefile:80: /usr/local/pgsql/8.3/lib/pgxs/src/makefiles/pgxs.mk: No such
 file or directory
 make[1]: *** No rule to make target
 `/usr/local/pgsql/8.3/lib/pgxs/src/makefiles/pgxs.mk'.  Stop.
 make[1]: Leaving directory `/c/thesrc/postgis-1.5.0b1/postgis'
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:22>
