[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
trac at osgeo.org
Sat Jan 9 01:38:19 PST 2010
Reporter: pramsey | Owner: mcayland
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 1.5.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by mcayland):
Nope, I'm afraid there is no hard-coding anywhere - the path to the PGXS
Makefile is always generated by "pg_config --pgxs".
Did you try and point to a different pg_config using --with-pgconfig? If
so, you may be suffering from the old PGXS bug where a pg_config in PATH
will still always take precendence over one specified using --with-
pgconfig. Note this bug was fixed in PostgreSQL 8.3.
So search hard for multiple pg_configs on your system...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/311#comment:23>
