[postgis-devel] [PostGIS] #380: Add files to final tarball
PostGIS trac at osgeo.org
Mon Jan 11 17:01:38 PST 2010
  Reporter:  pramsey  |       Owner:  pramsey
      Type:  defect   |      Status:  new
  Priority:  high     |   Milestone:  PostGIS 1.5.0
 Component:  postgis  |     Version:  trunk
Resolution:           |    Keywords:
Comment (by pramsey):
 And looking at the doc/Makefile it's clear that postgis_comments.sql is a
 generated file. The way to keep it in the built distribution is to remove
 it from the clean target, same as the generated HTML, which I just did at
 r5115
Ticket URL: <http://trac.osgeo.org/postgis/ticket/380#comment:2>
