[postgis-devel] [PostGIS] #311: Rename postgis.sql to postgis-1.5.sql
Nicklas =?utf-8?Q?Av=E9n?=
nicklas.aven at jordogskog.no
Thu Jan 14 04:35:21 PST 2010
I will try
> Reporter: pramsey | Owner: mcayland
> Type: defect | Status: reopened
> Priority: medium | Milestone: PostGIS 1.5.0
> Component: postgis | Version: trunk
>Resolution: | Keywords:
>Comment (by robe):
> Okay my 8.3 compiles and installs fine now under mingW. I still have an
> issue with make check that I didn't have with PostGIS 1.4 ever since that
> whole pre-install make check thing was introduced. Could be something
> funky with my batch script for packaging though. I haven't investigated
> the error yet.
> Nicklas, have you been able to do a full make check under mingW.
>Ticket URL:
>PostGIS
>The PostGIS Trac is used for bug, enhancement & task tracking, a user and developer wiki, and a view into the subversion code repository of PostGIS project.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100114/e228ffde/attachment.html>
