[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén nicklas.aven at jordogskog.no
Fri Jan 15 00:45:24 PST 2010
I had this error yestarday in the log-file not in the terminal:psql:postgis.sql:56: ERROR:  could not access file "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such file or directory I have never noticed this /00-regress-install/lib
-path before, and I don't fysically see it. What is that. I see you have it too. /Nicklas
2010-01-15 Paragon Corporation wrote:
>Nicklas,> >I forgot which error you get.  Mine gets screwed up by the sed thing so I usually have to cut that out and hard code the postgis.sql path. Worked perfectly in 1.4 as I didn't have to do any of that.  Things went downhill when we introduced that pre install make check> >Snippet of my error log looks like this.> >c:/projects/pg/pg83/lib/POSTGR~1/pgxs/src/MAKEFI~1/pgxs.mk:209: warning: ignoring old commands for target `clean'
>gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes stringbuffer.o shpopen.o dbfopen.o getopt.o shp2pgsql-core.o shp2pgsql-cli.o ../liblwgeom/liblwgeom.a -o shp2pgsql.exe -liconv -lm
>gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes shpopen.o dbfopen.o getopt.o pgsql2shp.o ../liblwgeom/liblwgeom.a -liconv -Lc:/projects/pg/pg83/lib -lpq -lm -o pgsql2shp.exe
>gcc -g -O2  -DDLL_EXPORT -DPIC  -Wall -Wmissing-prototypes -mwindows stringbuffer.o shpopen.o dbfopen.o shp2pgsql-core.o shp2pgsql-gui.o getopt.o ../liblwgeom/liblwgeom.a shp2pgsql-gui.res -o shp2pgsql-gui.exe -Lc:/gtkbundle/lib -lgtk-win32-2.0 -lgdk-win32-2.0 -latk-1.0 -lgio-2.0 -lgdk_pixbuf-2.0 -lpangowin32-1.0 -lgdi32 -lpangocairo-1.0 -lpango-1.0 -lcairo -lgobject-2.0 -lgmodule-2.0 -lglib-2.0 -lintl   -liconv -Lc:/projects/pg/pg83/lib -lpq -lm
>/bin/sh.exe c:/projects/pg/pg83/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -c shp2pgsql-gui.exe /c/projects/postgis/trunk/regress/00-regress-install/bin
>/bin/sh.exe c:/projects/pg/pg83/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -c pgsql2shp.exe /c/projects/postgis/trunk/regress/00-regress-install/bin
>/bin/sh.exe c:/projects/pg/pg83/lib/POSTGR~1/pgxs/src/MAKEFI~1/../../config/install-sh -c shp2pgsql.exe /c/projects/postgis/trunk/regress/00-regress-install/bin
>make[2]: Leaving directory `/c/projects/postgis/trunk/loader'
>sed 's,$libdir,/c/projects/postgis/trunk/regress/00-regress-install/lib,g' ../postgis/postgis.sql > postgis.sql
>Creating spatial db postgis_reg > >createlang: language "plpgsql" is already installed in database "postgis_reg"
>ERROR:  function postgis_lib_version() does not exist
>LINE 1: select postgis_lib_version()> >
>>From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Nicklas Avén
>Sent: Friday, January 15, 2010 2:19 AM
>To: PostGIS Development Discussion
>Subject: Re: [postgis-devel] PostGIS 1.5 beta2
 Do you get the same error on make check as I did, Regina? > >/Nicklas
>2010-01-14 Paragon Corporation wrote:
>+1 (make check still doesn't work for me, but I'd still like a beta 2)
>>Thanks,
>>Regina
>>________________________________________
>>[postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul Ramsey
>>[pramsey at opengeo.org]
>>Sent: Thursday, January 14, 2010 3:29 PM
>>Subject: [postgis-devel] PostGIS 1.5 beta2
>>Call for votes on releasing beta2, now that the install process seems to be
>>fixed up.
>>+1 !
>>P
>>_______________________________________________
>>postgis-devel mailing list
>>postgis-devel at postgis.refractions.net
>>http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>The substance of this message, including any attachments, may be
>>confidential, legally privileged and/or exempt from disclosure pursuant to
>>Massachusetts law. It is intended solely for the addressee. If you received
>>this in error, please contact the sender and delete the material from any
>>computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100115/c45af3a4/attachment.html>
