[postgis-devel] PostGIS 1.5 beta2
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Jan 15 03:31:51 PST 2010
Nicklas Avén wrote:
> But I still get:
> psql:postgis.sql:56: ERROR: could not access file
> "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such
> file or directory
Ah - wait a second. The backend won't have knowledge of MSYS-style paths
like /c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5 since it
doesn't run under MSYS.
Does the regress/postgis.sql file work if you do a global replace of:
with:
C:/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5
ATB,
Mark.
Mark Cave-Ayland - Senior Technical Architect
PostgreSQL - PostGIS
Sirius Corporation plc - control through freedom
http://www.siriusit.co.uk
t: +44 870 608 0063
Sirius Labs: http://www.siriusit.co.uk/labs
