[postgis-devel] PostGIS 1.5 beta2
Nicklas Avén
nicklas.aven at jordogskog.no
Fri Jan 15 03:38:21 PST 2010
Sorry Mark, I'm too novice where to do that change? /Nicklas
2010-01-15 Mark Cave-Ayland wrote:
Nicklas Avén wrote:
>> But I still get:
>> psql:postgis.sql:56: ERROR: could not access file
>> "/c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5": No such
>> file or directory
>Ah - wait a second. The backend won't have knowledge of MSYS-style paths
>like /c/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5 since it
>doesn't run under MSYS.
>Does the regress/postgis.sql file work if you do a global replace of:
>with:
>C:/utv/src/pg15/regress/00-regress-install/lib/postgis-1.5
>ATB,
>Mark.
>Mark Cave-Ayland - Senior Technical Architect
>PostgreSQL - PostGIS
>Sirius Corporation plc - control through freedom
>http://www.siriusit.co.uk
>t: +44 870 608 0063
>Sirius Labs: http://www.siriusit.co.uk/labs
>_______________________________________________
>postgis-devel mailing list
>postgis-devel at postgis.refractions.net
>http://postgis.refractions.net/mailman/listinfo/postgis-devel
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20100115/ac7a38dd/attachment.html>
