[postgis-devel] Adding Functions w/o Adding
Paragon Corporation lr at pcorp.us
Fri Jan 22 16:20:22 PST 2010
+1
All,
I have a client who needs a custom function added. Since we're well into
release, obviously the SQL API can't change, or really any code in
underneath any existing SQL functions.
However, I can implement the function as a completely additive thing (and in
fact have), so it affects the stability of existing functions not at all.
And I can leave the SQL API alone, and simple ship the CREATE FUNCTION code
directly to the client.
http://trac.osgeo.org/postgis/attachment/ticket/390/addmeasure.patch
They get the benefit of a quick turnaround on a new feature, we maintain our
contract with respect to leaving the API unchanged through minor releases.
I'd like to apply this patch into stable branches so folks who want it can
have it, by running the CREATE FUNCTION code themselves.
Paul
Paul Ramsey
OpenGeo - http://opengeo.org
The secret sauce is called... PostGIS.
postgis-devel mailing list
postgis-devel at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-devel
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure pursuant to
Massachusetts law. It is intended solely for the addressee. If you received
this in error, please contact the sender and delete the material from any
computer.
