[postgis-devel] Proposing 1.5.0
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jan 26 12:26:45 PST 2010
This test just ran successfully for me under Centos 5.4 in a 32bit VM.
Coming back into your court... :)
P
On Tue, Jan 26, 2010 at 12:06 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> Platform difference or regression? This test works for me on 1.3, 1.4 and 1.5.
> -- #11 --
> SELECT '#11', ST_Distance (a.g, ST_Intersection(b.g, a.g)) AS distance
> FROM (SELECT '01020000000200000050E8303FC2E85141B017CFC05A825541000000E0C0E85141000000205C825541'::geometry
> AS g) a,
> (SELECT 'LINESTRING(4694792.35840419
> 5638508.89950758,4694793.20840419 5638506.34950758)'::geometry AS g)
> b;
> On Tue, Jan 26, 2010 at 11:53 AM, Kevin Neufeld
> <kneufeld at refractions.net> wrote:
>> On Centos 5.2,
>> make check
>> regress_ogc_prep. ok
>> regress_bdpoly. ok
>> regress_proj. ok
>> dumppoints. ok
>> wmsservers. ok
>> tickets. failed (diff expected obtained: /tmp/pgis_reg_5126/test_47_diff)
>> Run tests: 47
>> Failed: 1
>> [buildbot at falcon postgis-1.5.0]$ cat /tmp/pgis_reg_5126/test_47_diff
>> *** tickets_expected Fri Jan 15 00:13:19 2010
>> --- /tmp/pgis_reg_5126/test_47_out Tue Jan 26 11:48:01 2010
>> *** 1,5 ****
>> #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
>> ! #11|0
>> #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
>> t
>> ERROR: AddGeometryColumns() - invalid SRID
>> --- 1,5 ----
>> ! #11|0.889477943128855
>> t
>> On 1/26/2010 11:40 AM, Paul Ramsey wrote:
>>> I have placed a tarball for testing here:
>>> http://dl.dropbox.com/u/1184727/postgis-1.5.0.tar.gz
>>> I am going to test on Solaris then come back with my vote for approval.
>>> P
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
