[postgis-devel] Proposing 1.5.0
Paul Ramsey
pramsey at cleverelephant.ca
Tue Jan 26 12:42:55 PST 2010
Regression tests also passed cleanly on OpenSolaris.
P
On Tue, Jan 26, 2010 at 12:26 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> This test just ran successfully for me under Centos 5.4 in a 32bit VM.
> Coming back into your court... :)
> P
> On Tue, Jan 26, 2010 at 12:06 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> Platform difference or regression? This test works for me on 1.3, 1.4 and 1.5.
>> -- #11 --
>> SELECT '#11', ST_Distance (a.g, ST_Intersection(b.g, a.g)) AS distance
>> FROM (SELECT '01020000000200000050E8303FC2E85141B017CFC05A825541000000E0C0E85141000000205C825541'::geometry
>> AS g) a,
>> (SELECT 'LINESTRING(4694792.35840419
>> 5638508.89950758,4694793.20840419 5638506.34950758)'::geometry AS g)
>> b;
>> On Tue, Jan 26, 2010 at 11:53 AM, Kevin Neufeld
>> <kneufeld at refractions.net> wrote:
>>> On Centos 5.2,
>>> make check
>>> regress_ogc_prep. ok
>>> regress_bdpoly. ok
>>> regress_proj. ok
>>> dumppoints. ok
>>> wmsservers. ok
>>> tickets. failed (diff expected obtained: /tmp/pgis_reg_5126/test_47_diff)
>>> Run tests: 47
>>> Failed: 1
>>> [buildbot at falcon postgis-1.5.0]$ cat /tmp/pgis_reg_5126/test_47_diff
>>> *** tickets_expected Fri Jan 15 00:13:19 2010
>>> --- /tmp/pgis_reg_5126/test_47_out Tue Jan 26 11:48:01 2010
>>> *** 1,5 ****
>>> #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
>>> ! #11|0
>>> #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
>>> t
>>> ERROR: AddGeometryColumns() - invalid SRID
>>> --- 1,5 ----
>>> ! #11|0.889477943128855
>>> t
>>> On 1/26/2010 11:40 AM, Paul Ramsey wrote:
>>>> I have placed a tarball for testing here:
>>>> http://dl.dropbox.com/u/1184727/postgis-1.5.0.tar.gz
>>>> I am going to test on Solaris then come back with my vote for approval.
>>>> P
>>>> _______________________________________________
>>>> postgis-devel mailing list
>>>> postgis-devel at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
