[postgis-devel] Proposing 1.5.0
Kevin Neufeld
kneufeld at refractions.net
Tue Jan 26 13:00:33 PST 2010
I traced this to my installed version of geos. I accidentally configured postgis to use geos 3.1.0. I know the min
requirements are 3.1.1 now, but it's curious that configure ran just fine. Anywho, using 3.1.0, I got the one make
check failure reported below.
I retested with 3.2.0 and all tests ran without incident.
-- Kevin
On 1/26/2010 12:42 PM, Paul Ramsey wrote:
> Regression tests also passed cleanly on OpenSolaris.
> P
> On Tue, Jan 26, 2010 at 12:26 PM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
>> This test just ran successfully for me under Centos 5.4 in a 32bit VM.
>> Coming back into your court... :)
>> P
>> On Tue, Jan 26, 2010 at 12:06 PM, Paul Ramsey<pramsey at cleverelephant.ca> wrote:
>>> Platform difference or regression? This test works for me on 1.3, 1.4 and 1.5.
>>> -- #11 --
>>> SELECT '#11', ST_Distance (a.g, ST_Intersection(b.g, a.g)) AS distance
>>> FROM (SELECT '01020000000200000050E8303FC2E85141B017CFC05A825541000000E0C0E85141000000205C825541'::geometry
>>> AS g) a,
>>> (SELECT 'LINESTRING(4694792.35840419
>>> 5638508.89950758,4694793.20840419 5638506.34950758)'::geometry AS g)
>>> b;
>>> On Tue, Jan 26, 2010 at 11:53 AM, Kevin Neufeld
>>> <kneufeld at refractions.net> wrote:
>>>> On Centos 5.2,
>>>> make check
>>>> regress_ogc_prep. ok
>>>> regress_bdpoly. ok
>>>> regress_proj. ok
>>>> dumppoints. ok
>>>> wmsservers. ok
>>>> tickets. failed (diff expected obtained: /tmp/pgis_reg_5126/test_47_diff)
>>>> Run tests: 47
>>>> Failed: 1
>>>> [buildbot at falcon postgis-1.5.0]$ cat /tmp/pgis_reg_5126/test_47_diff
>>>> *** tickets_expected Fri Jan 15 00:13:19 2010
>>>> --- /tmp/pgis_reg_5126/test_47_out Tue Jan 26 11:48:01 2010
>>>> *** 1,5 ****
>>>> #2|POLYGON((1 1,1 2,2 2,3 2,3 1,2 1,1 1))
>>>> ! #11|0
>>>> #21|SRID=31293;POINTM(6220.13 5337367.145 4566)
>>>> t
>>>> ERROR: AddGeometryColumns() - invalid SRID
>>>> --- 1,5 ----
>>>> ! #11|0.889477943128855
>>>> t
>>>> On 1/26/2010 11:40 AM, Paul Ramsey wrote:
>>>>> I have placed a tarball for testing here:
>>>>> http://dl.dropbox.com/u/1184727/postgis-1.5.0.tar.gz
>>>>> I am going to test on Solaris then come back with my vote for approval.
>>>>> P
>>>>> _______________________________________________
>>>>> postgis-devel mailing list
>>>>> postgis-devel at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
